Curve from Expression
I’m a Grasshopper newbie, and I’m trying to create a curve from a sine wave that is diminished in both the amplitude and the time domain (both x and z dimensions) using the golden ration (1/phi or .618…). I’m not a math guy, and so far I’m only able to get the sine wave showing in Rhino (6).
My thinking is that if I can insert a ‘multiplier’ before the x and z inputs of the ‘construct point’ module, each multiplier with the 1/phi value, that it should work. But I don’t know how to do this. And I’m guessing there’s a better way anyway.
Thanks for any clues!
Phi_Curve.gh (8.0 KB)
Hi Joe,
there is a multiply block you can use for that:
Phi_Curve_wd.gh (8.8 KB)
Does that help?
-Willem
It’s good to know now how to add that type of function as a component.
I was wrong, however, in thinking that would do what I wanted it to do - thus proving I feel asleep too often in math class.
Here’s a hand-drawn approximation of the curve I’m trying to create perfectly:
HandDrawn
Thanks Willem!
The derivation is left as an exercise for the reader:
diminished sine.gh (6.0 KB)
I hadn’t really looked at this for a few years and didn’t realize some of the parameters limited the range, so here’s an updated version.
diminished sine - wider range.gh (7.0 KB)
[off topic] @akilli
i just checked your website out…
weird but, i’m pretty sure i live on the next street over from you… the one that starts with F
:smiley:
I thought I felt a disturbance in the Force. We have to get together some time.
sin.gh (10.0 KB)
Thank you Ethan! It will take me some time to figure out exactly what you’ve done here, but I greatly appreciate the head-start you’ve provided.
Thanks Seghier - I’ll investigate your method to learn more about your solution.
Much appreciated!
