I wrote a diagrid definition using relative item component. I would like now to interpolate this diagrid lines to get a curved shape in this grid. I can´t figure it out how. Someone have any suggestion?
Diagrid.gh (8.2 KB)
Best to upload your definition. See point 3 in the link below.
Sorry about that! Already uploaded the definition. Thanks for the advice mate!
use ‘interpolate’ component
Another way , you need Pufferfish bounding rectangle or you can use regular component
Diagrid2.gh (20.5 KB)
My problem is on how to organize/select the data in order to interpolate the points. Do you have any suggestion?
If you are ok with a Python based solution, this might work for you (the code can probably be a lot more efficient).
Diagrid_V2.gh (7.6 KB)
Pretty clean, mate! Cheers
