I need to verify if two closed curves are one in the other but in the attached example it seems that the RhinoPlanarClosedCurveContainmentTest function returns a wrong result.
If I move the curves or enlarge/reduce the tolerance it works.
Hi @dale,
your sample works fine but if I set the DocProperties tolerance at 0.001 unit (instead of 0.01 unit) and use the ON_xy_plane, then the RhinoPlanarClosedCurveContainmentTest returns 0.
I used the following code:
CRhinoCommand::result CCommandSampleClosedCurveContainment::RunCommand(const CRhinoCommandContext& context)
CRhGetPlanarClosedCurve go(context.m_doc.AbsoluteTolerance());
go.SetCommandPrompt(L"Select two closed planar curves for containment test");
go.GetObjects(2, 2);
if (go.CommandResult() != CRhinoCommand::success)
return go.CommandResult();
const ON_Curve* curve0 = go.Object(0).Curve();
const ON_Curve* curve1 = go.Object(1).Curve();
if (nullptr == curve0 || nullptr == curve1)
return CRhinoCommand::failure;
const double tolerance = context.m_doc.AbsoluteTolerance();
ON_Plane plane0, plane1;
if (!curve0->IsPlanar(&plane0, tolerance) || !curve1->IsPlanar(&plane1, tolerance))
if (!curve0->IsInPlane(ON_xy_plane, tolerance) || !curve1->IsInPlane(ON_xy_plane, tolerance))
RhinoApp().Print(L"Curves are not in XY-plane.\n");
return CRhinoCommand::success;
const int rc = RhinoPlanarClosedCurveContainmentTest(*curve0, *curve1, ON_xy_plane, tolerance);
if (rc == 0)
RhinoApp().Print(L"The regions bounded by the curves are disjoint.\n");
else if (rc == 1)
RhinoApp().Print(L"The two curves intersect.\n");
else if (rc == 2)
RhinoApp().Print(L"The region bounded by the first curve is inside of the second curve.\n");
else
RhinoApp().Print(L"The region bounded by the second curve is inside of the first curve.\n");
I can get around the problem using the IsPlanar function instead of using ON_xy_plane but I’ll be glad to understand what is the problem. It is odd that with a smaller tolerance it doesn’t work, isn’t it? It should be more accurate, I suppose.
Looks like some of the curve control points have some floating noice, as their z-coordinate is not exactly 0.0. You might consider projecting curves onto the world xy-plane.
