Curve and Arc Utlilities
Hi Pascal,
Is it possible to modify the code from the curve and arc utilities to select a range of radii?
For example select radii from >100 or <300.
I am by no means competent in coding, so not sure what it would involve to modify the existing code to be able to do that.
Any help greatly appreciated.
Cheers
Alex
Hi Alex - @alexbabaeff - see if this does the right thing - I added
SelArcRange
Unblock the rhp file in Windows, then drag and drop onto Rhino. Make sure to move, delete, or rename the previous one.
CurveAndArcUtilities.rhp (70 KB)
Bit late to the party, here are a couple of scripts from my library just in case.
SelByRadius.py (2.8 KB)
SelSameRadArcsCircles.py (3.0 KB)
