How do I make the panel glass so it’ll render as transparent? I don’t see where it’s selectable?
Hi @Djhg, you can assign a transparent material to the Glass component from the Window styles dialog (if this glass belongs to a window):
@djhg I didn’t see you were refferring to the glass component of a curtain wall. But the process is the same. In this case you need to assgin the material to the “Cell” component:
Got it. Thanks.
