Is it possible to close this gap between the glass and the frame
Hi @11170 I guess this is a bug. Run the vaUpdate command on this curtain wall, just in case this solves the issue. Could you send that model to visualarq@asuni.com so we can revise it?
Thanks!
Hello, this issue have been just fixed. It will be available in the next VisualARQ’s revision.
Thanks
אייל סיליס
שיח אדריכלים
0526309015
www.siah-arch.com
