Ctrl + shift + drag shortcut does not work
Hi! When I try to rewire more than one wire with the LMB + ctrl + shift + drag shortcut it doesn’t work properly, instead of rewiring it lets me move arround the document as if I was useing the RMB.
Does someone knows why this shortcut doesn’t work? The other shortcuts work correctly.
Thanku for support
Hi Paula -
It looks like you have written your post on an Apple device. If you are running Grasshopper on a Mac, you’ll need to use cmd + Shift instead of ctrl + Shift.
Hi, thank you for the fast answer,
I’m actually useing rhino with a Windows device, in fact the ctrl + drag and shift + drag shortcuts do work, but when useing both together it doesn’t…
Hi Paula -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR26 2023-1-9 (Rhino 7, 7.26.23009.07001, Git hash:master @ 92abcf7c453c78a236526390d91d0ac1f6779143)
License type: Evaluación, build 2023-01-09
License details: Cloud Zoo
Expires on: 2023-04-17
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 3Gb)
Computer platform: DESKTOP
Primary display: Parallels Display Adapter (WDDM) (Parallels) Memory: 1GB, Driver date: 11-24-2021 (M-D-Y).
> External USB display device with 3 adapter port(s)
Primary OpenGL: Parallels using Intel(R) HD Graphics 6000 (Compat): Parallels and Intel Inc… OpenGL Ver: 3.3 INTEL-18.8.5
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Parallels and Intel Inc.
Render version: 3.3
Shading Language: 3.30
Driver Date: NA
Driver Version: NA
Z-Buffer depth: 24 bits
Total Video Memory: 1561258 KB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.26.23009.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.26.23009.7001
Hi Paula -
I’m afraid that running Rhino under Parallels is not supported. Some things might work, others won’t.
Hi wim,
I’ve just discovered how it works,
with parallel to rewire more than one wire the comand is “comand + ctrl + shift”
Thank you for the support!!
