Crystals growing simulation
hello, I hope you are well, I have a problem regarding a geometry, where from this I come to simulate the growth and adherence of crystals within the morphology, that is why I work in a first instance within these tubes , but when trying to generate a solid union in these cubes that were made in the image, I could not generate that they are a single piece.
It would be very helpful if someone could teach me or help me on how to generate this simulation of crystal growth on surfaces and that after this simulation, it can be generated as a single morphology and not independent elements. I hope you are fine. greetings
Solid Union
And you better share your GH no matter how simple it is, screenshots will significantly reduce your chances of getting an efficient answer.
CRYSTALS.gh (12.3 KB)
