CRhinoPageView & CRhinoDetailViewObject
#1
I would like to annotate some objects on a layout. The objects are 3D and I want the annotations (some text blocks, for example) to be on the layout (2D).
But I can’t find the function to convert a 3D point (W coordinates) into a 2D point (paper coordinates).
Does this exist ?
Thanks,
Jean
P.S.: My question is about C++ SDK.
Annotation on a layout
(Dale Fugier) #2
Hi Jean,
There is no such thing as “paper coordinates”. You draw in world coordinates when in a layout, just like you would if you were in a normal viewport.
(Steve Baer) #3
There is a GetPageXforms function on the CRhinoDetailViewObject if you are trying to transform between spaces
#4
I attach an example with a box and 2 text blocks. The red one has been drawn in 3D (not what I’m looking for). The green one has been drawn in 2D (this is what I need).
What I’m trying to do is to put an annotation like the green one on a corner of the displayed box. That for I need to map between world coordinates and 2D coordinates (at least, that’s what I think but I may be wrong).
#5
Thanks Steve.
I’ll give a try (although I was looking for something in Rhino 4 sdk).
(Steve Baer) #6
In Rhino 4 get the CRhinoViewport from the detail object and call GetXform
#7
Thanks again Steve.
It looks like I’m not far from the goal but I miss a kind of scale factor.
I get the Xform:
ON_Xform world2camera;
detailViewObj->Viewport().m_v.m_vp.GetXform (
ON::world_cs, ON::camera_cs, world2camera);
then activate page view’s main viewport
  RhinoApp().SetActiveViewport (pageView->MainViewport().ViewportId());
then compute projectedPoint:
ON_3dPoint projectedPoint = world2camera * myWorldPoint;
then add a text block by running _Text command:
   myStream << L"-_Text " << projectedPoint.x
                          << L"," << projectedPoint.y
                          << L"," << projectedPoint.z
         << L" Height=5 " << "myText";
I’ve run a test with a selection of several objects. And the resulting text blocks almost well positioned: there is just a scale factor (see attached snapshot).
Any clue about which scale I should use ?
(Steve Baer) #8
I would get a world->screen transform from the detail viewport and a screen->world transform for the page viewport. Combining these will transform a point from detail space to page space.
#9
I got it.
Thanks very much, Steve !
#10
Hi @stevebaer, @dale,
i’ve used above way to transform objects (dimensions and curves) from model space to page space but have a problem with deviation. My detail viewport has the same size as the layout page, scaling is 1:1, however, i get deviations up to 0.25 mm which also changes dimension text from eg. 10.0 to 9.76.
Is there an alternate way to make this transform using Rhino 5 ?
Edit: i’ll attach 1 example page and script. Please run the script, pick the detail on Page 1, then a point is created. If you zoom in, the deviation from the origin point in modelspace is 0.25 (measured in page units).
Example.3dm (75.4 KB)
Example.py (856 Bytes)
_
c.
(Dale Fugier) #11
Hi @clement,
Does the ChangeSpace command provide the accuracy you need?
– Dale
#12
Hi @Dale,
yes this looks promising and much more accurate than my script example. I’ve found how to use it in V5 by scripting the command. How would i do this with code so i can avoid selecting an object instead ? (I’ve seen your example here but have no idea how to convert it in python) In Rhino Common for V5 i only found the PageViewSpaceChange Event but no method to actually perform the change.
btw. for the simple case i demonstrated above i’ve been able to transform using a simple translation matrix (since the detail only shows a top view). But i’d like to apply the same what _ChangeSpace does using other views in my details too.
_
c.
Faulty output of GetTransform() function after using ZoomBoundingBox() on detail view
(Dale Fugier) #13
Hi @clement,
I think scripting the ChangeSpace command is your best option in Rhino 5.
Rhino 6 has has new DetailViewObject.WorldToPageTransform and DetailViewObject.PageToWorldTransform properties which provide the necessary transforms.
If you want to run your code through RhinoScript, you can use XformWorldToLayout andXFormLayoutToWorld```.
– Dale
