If I want to select two different sets of points using a CRhinoGetObject inside a command plugin I am currently finding that I need to insert a “dummy” selection of a non-point object as per below. If I don’t do this there is no prompt to select the destination points and the origin points appear to be automatically selected instead. Is there a way to reset select state or otherwise force the explicit selection of two different sets of points for this type of workflow?
That worked like a charm! I am quite new to Rhino Plugin development and still feeling out the SDK. Help with these little things is much appreciated. Thank you.
