I’ve written (with help from Claude.ai) a python script (Rhino 7 IronPython 2.7) that tweaks some V-Ray materials (that have already been convert from Rhino materials, with the name leaf or flower in it).
The diffuse tex is set up in a TexBitmap with the the filename XYZ_albedo.jpg
I want to create 2 new TexBitmaps, following the naming scheme: XYZ_translucency.jpg and XYZ_glossiness.jpg (with the same file location as the diffuse map), and map them to brdf.translucency_color_tex and brdf.reflect_glossiness_tex
Can someone explain how to do this?
import Rhino
import System
import rhVRay as vray
with vray.Scene.Transaction() as f:
# Get all V-Ray materials of type MtlSingleBRDF from the scene
vray_materials = vray.Scene.PluginsByType("MtlSingleBRDF", True)
# Loop through each V-Ray material
for material in vray_materials:
material_name = material.Name
with vray.Scene.Transaction() as t:
for material in vray.Scene.Materials:
brdf = vray.Scene[material.brdf]
if brdf.Type != "BRDFVRayMtl":
continue
# Check if name contains "leaf" OR "flower"
name_lower = brdf.Name.lower()
if "leaf" not in name_lower and "flower" not in name_lower:
continue
print("Processing: \"{0}\" ...".format(brdf.Name))
brdf.translucency = 6
brdf.translucency_amount = 0.3
brdf.refract_ior = 1.6
brdf.fresnel_ior = 1.3
brdf.refract_glossiness = 1
brdf.refract_thin_walled = 1
brdf.reflect_color = [1, 1, 1, 1.0]
brdf.bump_amount_float = 1
print("Done!")
