Creating SubDs for complex meshes
Dear all,
I am new to Rhino, currently using Rhino 7 (90-day trial version).
My aim is to convert an STL mesh (Fig.1) to STEP file for conducting CFD Analyses.
I have used the following steps:
  1. Open .STL file
  2. MeshRepair > Check > Repair > “Good Mesh” (Fig.2)
  3. QuadRemesh > Default settings > Preview
As I use QuadRemesh feature to create SubD, the QuadMesh generation task freezes at 75%.
Has anyone experienced the same with complex meshes and could they please help in this regard?
I greatly appreciate your response(s).
Many thanks,
Rajas
Figures:
Fig.1 : STL file
Fig. 2: MeshRepair report
Hi @rg861
This appears to be the same question as you posted here
Please avoid duplicate threads.
It may be the settings used with QuadRemesh or an issue with the mesh not necessarily making it a bad mesh. One guess without seeing the mesh is to try turning off detect hard edges. Post the mesh if you still have an issue at 75% please.
as your geometry has repetition / symmetry, you may also want to try to only us a smaller section (3x3x3) elements - generate the Sud-D and rearrange / array the inner 1x1x section…
@Tom_P,
Thank you, I tried converting a single cell of lattice structure from STL to SubD, and it worked!
Although I’m not proceeding with this approach due to some other reasons, I am grateful for your contribution!
Hi, are you still using Rhino for dealing with TPMS structures? I’ve recently encountered similar issues
