Is it possible to create a revolved object and then use extruded curves to create negative space while keeping the piece solid? When I use the split command, the piece becomes hollow. Below is a pic and the file. Revolve objects are new to me-maybe there is a better way to create a similar outcome?
By using the command on the red _Cap polysurface you get a solid (and at this point you can use the 3-cylinder for a _BooleanDifference. Alternatively, maybe this can help (the result is the smooth cutting area.) Use at your pleasure the distance _crv of cutting Blue.
