I’m trying to create a unique light for Rhino Render. I can do it easily enough in Vray just can’t seem to find that option in Rhino. I’m attempting to create 2 different spots with different color properties.
Use the _Spotlight
command to create a new spot light. Once you have placed it select the light, then change its settings in the object properties panel.
Thank you Nathan. Slightly different workflow than I have acquired in vray, but makes perfect sense. I’m really liking Rhino Render.
Good to hear you like Rhino Render.
In the Render menu you can also find the different light types to create. Additionally you could create them using the Lights panel.
