Hi everyone!
I need to create pedestrian paths on the floor with both a gradient and the pixel effect. I would like to get a result as the picture I have attached. The resulting grid or division of the surface has to have squares with sides of 0,40m. I want to use points and curves to generate the gradient and those pixels have to have a maximum and minimum size (0,40m-0,35m-0,30m-0,25m-0,20m).
I did a definition but I have 3 problems:
1_I began with the component square
, but I need to use different surfaces like the polygon I have attached in the grasshopper file.
2_I used the component Rectangle
to get the “pixels”, but all squares are generated in one corner, not in the center of points.
3_I cannot set the size of the pixels and control the maximum and minimum dimension.
Thanks in advance!
Pixelated floor tile.gh (10.7 KB)
