SDKRailRevolveBug.3dm (135.0 KB)
Somehow NurbsSurface.CreateRailRevolvedSurface() is turning a polycurve with 5 segments into a single surface, but only on the replay.
Top: when first created; Bottom: after history replay
I don’t know how this is possible (polysrf → srf). Plus, the same line of code creates the Brep for both creation and history replay:
NurbsSurface.CreateRailRevolvedSurface(profileCurve, railCurve, axisLine, false).ToBrep()
Here are the relevant What’s:
PolyCurve
curve
Object name: (not named)
Layer name: Profile
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: 563238F9-C201-411d-A7B1-13895A0317AD
Plug-in: Rhino
description: AutoPointsOn
saved in file: no
copy count: 1
UserData ID: CE28DE29-F4C5-4faa-A50A-C3A6849B6329
Plug-in: 17b3ecda-17ba-4e45-9e67-a2b8d9be520d
description: User text (0 entries)
saved in file: yes
copy count: 15
UserData ID: 0D007E84-79CC-4b4a-850B-C23EF2CEC640
Plug-in: Rhino
description: Hide user data
saved in file: yes
copy count: 13
Geometry:
Valid curve.
Closed polycurve with 5 curve segments.
Segment 1:
Open NURBS curve
start = (-7.58378,0,14.9537)
end = (-7.3311,-2.77556e-17,15.7731)
degree = 3
control points: non-rational, count=6
knots: uniform (delta=0.310047), domain = 2.45935 to 3.38949
clamped at start and end
Segment 2:
Open NURBS curve
start = (-7.3311,-2.77556e-17,15.7731)
end = (-7.10786,-1.38778e-17,15.5498)
degree = 1
control points: non-rational, count=2
knots: uniform (delta=0.315713), domain = 3.38949 to 3.7052
Segment 3:
Open NURBS curve
start = (-7.10786,-1.38778e-17,15.5498)
end = (-5.91628,0,13.9982)
degree = 3
control points: non-rational, count=5
knots: uniform (delta=1.37161), domain = 3.7052 to 6.44843
Segment 4:
Open NURBS curve
start = (-5.91628,0,13.9982)
end = (-10.06,0,14.3759)
degree = 5
control points: non-rational, count=11
knots: uniform (delta=1), domain = 6.44843 to 12.4484
Segment 5:
Line
start = (-10.06,0,14.3759)
end = (-7.58378,0,14.9537)
domain = 12.4484 to 14.9078
line length = 2.54271
History:
Record index: 1
Record id: DE60084C-7B39-4180-9676-D7B0C7A6C365
Command: Transform
Original PolySrf
polysurface
Layer name: Srf
Render Material:
source = from layer
index = -1
Geometry:
Valid polysurface.
closed solid polysurface with 5 surfaces.
Edge Tally:
5 seam edges
5 manifold edges
= 10 total edges
Edge Tolerances: all 0
Vertex Tolerances: all 0
Render mesh: 5 meshes 4175 vertices 4476 polygons
Created with fast meshing parameters.
Analysis mesh: none present
History:
Record index: 2
Record id: 9FDB3D60-F810-4883-AAD3-6AF7768D297A
Command: Revolv
Replay Srf
surface
Layer name: Srf
Render Material:
source = from layer
index = -1
Attribute UserData:
saved in file: yes
copy count: 12
Geometry:
Valid surface.
closed surface.
NURBS Surface"U": Periodic degree =3 CV count = 15 (0 <= U <= 12)
"V": Closed degree =5 CV count = 40 (2.45935 <= V <= 14.9078)
Edge Tally:
2 seam edges
Render mesh: 1 mesh 3137 vertices 2352 polygons
History:
Record index: 0
Record id: 4B7BFA7E-A64E-4c1e-B131-57E20F324F83
Command: Revolv
@Gijs has RailRevolveSG that is very similar to this. Posting his cause it’s c# and shows the exact same behavior:
