Created MOSAIC
My GAWD! Perfect! Bless you Laurent! You are a true maestro !!!
How can I bake the surface with the coloured surface on 20190322_mosaic_v5.gh ?
Thank you very much!
You have just to right click then click on bake. you must put the mouse on the icon of the custom preview component.
Hello Pavel M
Can you send your email
Hi Pavel
I like test the plugin Artificial Mosaic Creator, can you please publish it.
If you dont have where is possible get it
Hello
Some of the people on this forum have access to the “Artifical Mosaic Created” plugin that you can share with people who are interested in testing
Thank you
These links still work :backhand_index_pointing_down:
Hello Will
This is the “Artifical Mosaic Created” plugin?
Thank you for your support and i’m sorry for what happened
Looks like the “Artificial Mosaic Creator” is available as a .jar applet at the bottom of the link that Pavel posted (see my updated post above).
Dear Laurent Delrieu,
you work is amazing.
could you please providing the full .gh for the square tiles
Do i need to draw the curves or they are automatically created?
I would greatly appreciate any support you can provide in this regard.
Cube tool must be here
For other shape you could use Wordle from Nautilus plugin, but the tool doesn’t try to align shapes to a vector field.
2 min for an image 700 x 1000 pixels
mosaic wordle.gh (13.5 KB)
Amazing work
Thank you for your time and support
As you can see this is always what is happen with me when using GH and Dynamo, updated nodes and new libraries. :frowning:
When you open the script Grasshopper must tell you which plugin are missing. I think it is Anemone.
perfect
i’ll try it tomorrow mornig
one last question, how about the script for the beautiful unicorn, does it have any unique node!
strong text
I don’t remember, I have done a lot of variation of these tools, with square then adding color, then adding a limited number of color
this is almost the same procedure in python
Some other way to do something slightly related to Mosaic
square oriented_Nautilus.gh (22.4 KB)
Par Toutatis! Obélix turned out great. :tophat:
I reckon you do the square placement with circle packing, but how do you decide on their rotation?
I am creating a Weight Map using pixels Luminance
Pixels with less than a threshold, here 0.2 are fixed
This weight map is used to make a Vector Field that is also smoothed. It is not mandatory as I could also smooth more the weight map
 I didn’t spend too much time on that.
I just see that it is best to not use Unify option on Vector Smoothing
