Create SubDFriendly curve by code
Hi;
I try to create a SubDFriendly curve by code, Which friend has a good idea ?
        ON_3dPointArray points;
	points.Append(ON_3dPoint(0, 0, 0));
	points.Append(ON_3dPoint(0, 2, 0));
	points.Append(ON_3dPoint(2, 4, 0));
	points.Append(ON_3dPoint(4, 2, 0));
	points.Append(ON_3dPoint(4, 0, 0));
	ON_NurbsCurve* nc = ON_NurbsCurve::New();
	nc->CreateClampedUniformNurbs(3, 4, points.Count(), points);
	nc->IsSubDFriendly(true);//Try setting this parameter to work
	nc->SetSubDFriendlyTag(true);// And try setting this parameter to work
	if (nc->IsValid())
		context.m_doc.AddCurveObject(*nc);
		context.m_doc.Redraw();
	RhinoApp().ActiveDoc()->Redraw();
	return CRhinoCommand::success;
Hi @suc_kiet,
For example:
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
  points.Append(ON_3dPoint(0.0, 0.0, 0.0));
  points.Append(ON_3dPoint(0.0, 2.0, 0.0));
  points.Append(ON_3dPoint(2.0, 4.0, 0.0));
  points.Append(ON_3dPoint(4.0, 2.0, 0.0));
  points.Append(ON_3dPoint(4.0, 0.0, 0.0));
  ON_NurbsCurve nurb;
  nurb.CreateClampedUniformNurbs(3, 4, points.Count(), points.Array());
  if (nurb.IsValid())
    ON_NurbsCurve nurb_friendly;
    if (ON_SubD::CreateSubDFriendlyCurve(nurb, &nurb_friendly))
      context.m_doc.AddCurveObject(nurb_friendly);
    else
      context.m_doc.AddCurveObject(nurb);
Note, I’ve re-written your sample because it was leaking memory. CRhinoDoc::AddCurveObject makes a copy of the input curve. So make sure to delete the pointer you allocated with ON_NurbsCurve::New().
– Dale
Hi@dale;
Thank you, it run good.
So I must call “delete nc” after call “context.m_doc.AddCurveObject(*nc);”, right ?
Hi @suc_kiet,
You can do this:
ON_NurbsCurve curve;
// TODO...
context.m_doc.AddCurveObject(curve);
or this:
ON_NurbsCurve* ptr_curve = ON_NurbsCurve::New();
// TODO...
context.m_doc.AddCurveObject(*ptr_curve); // Copies ptr_curve data
delete ptr_curve; // Don't leak...
or this:
// TODO...
CRhinoCurveObject* ptr_curve_obj = new CRhinoCurveObject();
ptr_curve_obj->SetCurve(ptr_curve); // ptr_curve_obj now owns ptr_curve_obj
context.m_doc.AddObject(ptr_curve_obj);
Let me know if you have any qustions.
– Dale
Hi@dale;
Thank you for your help
