Create Solid using 2 non planar surfaces
I am trying to make a solid using 2 non planar surfaces as shown in the pic.
Is there any way to create this in GH?
I have tried sweep using curves but am not able to convert that into a solid later.
Extrude along isn’t giving an acceptable result as well.name radial extrude.gh (11.2 KB)
How about using Sweep 1?
name radial extrude_re.gh (12.0 KB)
Another way as I have not the Wood Bagots plugin
name radial extrudeLD.gh (11.0 KB)
got these error when i tried sweep 1
  1. A null section was removed from the list.
  2. At least a single section curve is required.
  3. Data conversion failed from Surface to Curve
Let me give it a try. Seems like a handy plugin
It is not a plugin, it is a C# script from this discussion
Thanks. Realised later :smiley:
