Create mesh and triangle mesh for selected objects
I ran into a group of problems and ask for help. First, I need to use the NonManifoldMerge command for the selected objects (Imprint between surfeaces (command)) on my video I call it without problems, but I don’t know how to call it using the Rhino C # API. After I need to make Mesh for these objects as shown in the video. Here is my code for creating a Mesh, but it still doesn’t appear in Rhino itself.
 protected override Result RunCommand (RhinoDoc doc, RunMode mode)
            doc.Views.RedrawEnabled = false;
            List <ObjRef> objRef = new List <ObjRef> ();
            using (GetObject go = new GetObject ())
                go.SetCommandPrompt ("Select objects");
                go.GeometryFilter = ObjectType.Surface;
                go.GroupSelect = true;
                go.GetMultiple (1, 0);
                if (go.CommandResult ()! = Result.Success)
                    return go.CommandResult ();
                for (int i = 0; i <go.ObjectCount; i ++)
                    objRef.Add (go.Object (i));
            foreach (var item in objRef)
                if (doc.Objects.Find (item.ObjectId) is RhinoObject rhinoObject)
                                     MeshingParameters meshingParameters = new MeshingParameters
                        Tolerance = 0.01,
                        MaximumEdgeLength = 5
                    rhinoObject.CreateMeshes (MeshType.Render, meshingParameters, true);
            doc.Views.RedrawEnabled = true;
            doc.Views.Redraw ();
            return Result.Success;
After I need to use the TriangulateMesh command using the Rhino C # API. If anyone has ideas on how to solve these problems, I will be very grateful in advance thanks))
With respect Dmitry))
I managed to make Mesh and Triangulate Mesh, but I don’t know how to call the NonManifoldMerge command in Rhino Api. How could this code be simplified? Thanks in advance))
        List<ObjRef> objRef = new List<ObjRef>();
        GetObject go = new GetObject();
        go.SetCommandPrompt("Select objects");
        go.GetMultiple(1, 0);
        if (go.CommandResult() != Result.Success)
            return go.CommandResult();
        for (int i = 0; i < go.ObjectCount; i++)
            if (doc.Objects.Find(go.Object(i).ObjectId) is RhinoObject rhinoObject)
                    Tolerance = 0.01,
                    MaximumEdgeLength = 8
                Mesh[] meshes = Mesh.CreateFromBrep(go.Object(i).Brep(), meshingParameters);
                if (meshes == null || meshes.Length == 0)
                    return Result.Failure;
                Mesh brep_mesh = new Mesh();
                foreach (Mesh mesh in meshes)
                    Mesh triangleMesh = Triangulate(mesh);
                    brep_mesh.Append(triangleMesh);
                doc.Objects.AddMesh(brep_mesh);
                doc.Views.Redraw();
        doc.Views.Redraw();
    private Mesh Triangulate(Mesh x)
        int facecount = x.Faces.Count;
        for (int i = 0; i < facecount; i++)
            var mf = x.Faces[i];
            if (mf.IsQuad)
                double dist1 = x.Vertices[mf.A].DistanceTo(x.Vertices[mf.C]);
                double dist2 = x.Vertices[mf.B].DistanceTo(x.Vertices[mf.D]);
                if (dist1 > dist2)
                    x.Faces.AddFace(mf.A, mf.B, mf.D);
                    x.Faces.AddFace(mf.B, mf.C, mf.D);
                else
                    x.Faces.AddFace(mf.A, mf.B, mf.C);
                    x.Faces.AddFace(mf.A, mf.C, mf.D);
        var newfaces = new List<MeshFace>();
        foreach (var mf in x.Faces)
            if (mf.IsTriangle) newfaces.Add(mf);
        x.Faces.Clear();
        x.Faces.AddFaces(newfaces);
        return x;
Hi @leusd100,
There is no SDK equivalent to what the NonmanifoldMerge command does. I can add something to the Rhino WIP if that help.
– Dale
Thanks for the quick response. If such a command does not exist in the Rhino API, but it works according to a certain algorithm. Could I implement the functionality of this command on my own? If possible, you could help implement this command.
Best regards, Dmitriy
Hi @leusd100,
Does this help?
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_MergeBreps.htm
– Dale
Unfortunately, this did not help. Perhaps I was mistaken in something. By the way, the logic of the BolleanUnion command does not fit. NonmanifoldMerge is needed. Here is my code how MergeBreps implemented:
        List<Brep> listBreps = new List<Brep>();
                listBreps.Add(go.Object(i).Brep());
        Brep.MergeBreps(listBreps, 1);
        foreach (var brep in listBreps)
                Tolerance = 0.01,
            Mesh[] meshes = Mesh.CreateFromBrep(brep, meshingParameters);
            doc.Views.Redraw();
        doc.Views.Redraw();
            if (mf.IsQuad)
                if (dist1 > dist2)
                else
        x.Faces.Clear();
        return x;
Best regards, Dmitry
Thank you very much)) Everything worked out, I just made a mistake
