Is there a way to create elevation views? If not it would be great to be able to create them with the same method as the 3d views.
There’s a component in the works, its not going to be like placing other views. The Elevations require the Elevation Marker to be placed parallel to the desired plane first, then an index of the Elevation being created (0-3).
Thanks Japhy, sounds good. Looking forward to it
