I want to put an elongated linear pattern in a polygonal curve. I want to use four linear patterns as a guide to make the linear patterns more oriented. I had to fill the curve with patterns, so I tried to make Voronoi and combine cells in the direction of the nearest guideline to make an elongated linear shape, but the pattern is not as smooth as I thought it would be, and the points of the cells are random, so I can’t make an elongated linear shape. Should I use anything other than Voronoi?
Four purple lines are the guidelines, and the polygonal curve line is the area you drew with a yellow highlighter. I drew a roughly linear bubble. Like this, the goal is to follow the direction of the four purple lines, but fill them up tightly.
I would appreciate it if you could let me know if there are other good ways.
Thank you very much. It’s what I wanted. I think it would be perfect if I did the bubble a little longer. Flowalong field + clustering I’ll try this way.
