Create a circle on a subd box to extrude it
Hey there iam looking for a way to recreate this in rhino.
in blender its called loop tools
i forwarded to a specific timecode
Hello - QuadRemesh will do that from an existing object - Set Detect hard edges, SubD output and SubD Creases if you want a subD object.
You can get a circle-based structure with QuadRemesh if you give it a guide curve - extrudin that into a hemisphere is a different matter - I’d go about it as above.
Thanks for your answer Pascal.
but i would need more control. The remeshing ist too unprecise
Another method, the result is better than without removal in the circle.
4
You can pull vertices to the selected curve using ToCurve option of Align command:
It’s your mesh.
With SubD there will be completely different results, instead of a sphere you get a square.
The question is about SubD.
Hi inju
Thank’s :thinking:
This seemed like a technique I should learn. However, when I try to do it I get different results. After SelVolumePipe and I select the rectangle, I get circle/dia request at the cursor that is perpendicular to the plane we want and I can do nothing else. This must be some setting?
