I can’t quite work out how to get perfectly circular holes in subd mode.
I’ve tried slightly extrude the center, and scaling the resulting face, then extruding into the opposite direction (apologies for the lack of technical terms), as below:
Thanks for that video, it was quite insightful - However, it doesn’t seem to work too well if you aren’t using a flat surface. This ellipsoid has a convex surface and doesn’t seem to respond too well when I try that method.
