Create a 4 points surfaces from two consecutive points of two list points
I have two lists of points. I would like to create surfaces from 4 points (two consecutive points of each points list).
Thanks in advance
3. Attach minimal versions of all the relevant files
:roll_eyes:
Okey sorry in attached screenshots and file.
stiffnners plates.gh (12.5 KB)
You didn’t internalize your surface.
Are you serious!! Show some respect.
I have uploaded just the grasshopper script and with the images you can understand the script and what I am trying to do.
relax
without your geometry we might understand what you are trying to do, but we do not know why you are not successfull.
the deconstruct brep you are using does give you a list of points for each brep. but it does depend on YOUR brep how long that list is. is there a fourth point in the list -you would have selected it the same way as you did with the other 3?
so how do we know what other point you are looking for
If you do not want to publish your design here - give us an other surface/brep (or a list of…) that creates the same problem you are facing.
…with respect shown
…but i guess you are looking for “relative Items”
I hope I am clear now, If you can see the first image I’ve uploaded in the second comment, I putted circle on two points components ( my two lists of points).
Since you selected single items, your lists are rather short. one Item. Your Problem ist about datatree. The adresses in your tree depend on the tree the breps were organized.
To be clear: you could save the time of those willing to help by internalizing geometry. Your Screenshots do Not Show datatreestructure. But thats your Problem you are hiding. Good luck.
stiffnners plates.gh (13.6 KB)
4 points surfaces from two points lists.3dm (9.2 MB)
Hi, in attached file rhino and grasshopper.
Thanks in advance !
Thank you so much for the response, but I would like to construct my surfaces by 4 points because I need to verifcate that all my points are in same plane.
4 points surfaces from two points lists.3dm (7.6 MB)
stiffness with 4 points surfaces .gh (19.4 KB)
I did a script for one surface, but I can’t manage the tree data to generate all the surfaces if you could suggest some ways
thnks
stiffnners plates a.gh (23.5 KB)
Grazie mille @leopoldomonzani
I am trying the script you send with an other point that i get from progection on other curves,I have selected the surfaces in order but it gives me points in random order
stiffness with 4 points surfaces .gh (20.5 KB)
stiffness with 4 points surfaces .gh (12.3 KB)
thank you, I have resolved those surfaces, my concern now is why I have those points with this order (3 1 2 0 ) not (0 1 2 3 )
thank you very much. learned and resolved.
