CPU + GPU (+ Holomark2_R6+R7)
In the last few months I upgraded my GPU from an old Quadro 4000 to an RTX 2080ti.
There has been a noticeable performance boost but I still get laggy panels and dialogs esp on really big models, and fairly show Layouts.
My question is, will upgrading the entire computer make much of a difference? Does a faster CPU increase the performance of the GPU and display?
I just ran Holomark2_R6. Here are the scores (full results below):
Rhino6, AA=8x Total Score: 130734 Total Runtime: 860.98 sec
Rhino6 AA=0 Total Score: 156578 Total Runtime: 1019.94 sec
Rhino7 AA=8x Total Score: 150346 Total Runtime: 957.34 sec
Rhino7 AA=0 Total Score: 153306 Total Runtime: 1007.69 sec
(Not sure how to interpret these results. Is a higher score and shorter runtime a better result?
How does this compare to what’s out there?):
Holomark 2 R6 v2,61
Total Score: 130734
GPU scores: 120190
GPU_01 - 143.90 fps - Cube 4 tests
GPU_02 - 41.30 fps - UDT Shape
GPU_03 - 59.90 fps - Wireframe
GPU_04 - 60.20 fps - Shaded
GPU_05 - 59.90 fps - Rendered
GPU_06 - 59.20 fps - Block Rendered
GPU_07 - 496 units Nurbs @ 5 fps in Wireframe
GPU_08 - 147 units Nurbs @ 5 fps in Shaded
GPU_09 - 37 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 59.90 fps - RenderMesh Render
GPU_11 - 59.90 fps - RenderMesh RenderSpeed
GPU_12 - 59.90 fps - JoinedMesh Render
GPU_13 - 59.90 fps - JoinedMesh RenderSpeed
GPU_14 - 168 units mesh @ 15 fps in Shaded
GPU_15 - 418 units mesh @ 15 fps in Render
GPU_16 - 1614 units mesh @ 15 fps in RenderSpeed
GPU_17 - 60.20 fps - mesh in Rendered Studio
GPU_18 - 16.60 fps - Nurbs in Rendered Studio
GPU_19 - 29.50 fps - Block Illustration
GPU_20 - 43.30 fps - 2D single
GPU_21 - 6.00 fps - 2D massive (20x)
CPU scores: 10544
CPU_01 - 9.82 sec - Booleans and Contours
CPU_02 - 2.40 sec - Twist and Taper (UDT)
CPU_03 - 13.65 sec - Meshing Mini
CPU_04 - 0.04 sec - Extract Render Mesh
CPU_05 - 0.04 sec - Join Render Mesh
CPU_06 - 15.84 sec - Reduce Mesh
CPU_07 - 1.17 sec - Calculating Technical display
CPU_08 - 4.46 sec - Making Silhouettes
System manufacturer
System Product Name
NVIDIA GeForce RTX 2080 Ti - 4095.0 MB
DriverVersion: 27.21.14.5167
Intel® Core™ i7-3930K CPU @ 3.20GHz
NumberOfCores: 6 NumberOfLogicalProcessors: 12
MaxClockSpeed: 3.2 GHz
TotalPhysicalMemory: 32.0 GB
Microsoft Windows 10 Pro
  • None - 64-bit
Rhino 6 sr 29 64 bit
AA level = 8
Holomark 2 R6 v2,61
Total Score: 156578
GPU scores: 143170
GPU_01 - 666.70 fps - Cube 4 tests
GPU_02 - 39.10 fps - UDT Shape
GPU_03 - 60.20 fps - Wireframe
GPU_05 - 60.20 fps - Rendered
GPU_06 - 59.90 fps - Block Rendered
GPU_07 - 615 units Nurbs @ 5 fps in Wireframe
GPU_08 - 156 units Nurbs @ 5 fps in Shaded
GPU_09 - 36 units Nurbs @ 5 fps in RenderSpeed
GPU_14 - 337 units mesh @ 15 fps in Shaded
GPU_15 - 409 units mesh @ 15 fps in Render
GPU_16 - 1707 units mesh @ 15 fps in RenderSpeed
GPU_18 - 16.90 fps - Nurbs in Rendered Studio
GPU_19 - 29.80 fps - Block Illustration
GPU_20 - 43.10 fps - 2D single
CPU scores: 13408
CPU_01 - 9.74 sec - Booleans and Contours
CPU_02 - 2.54 sec - Twist and Taper (UDT)
CPU_03 - 4.31 sec - Meshing Mini
CPU_04 - 0.03 sec - Extract Render Mesh
CPU_05 - 0.02 sec - Join Render Mesh
CPU_06 - 15.04 sec - Reduce Mesh
CPU_07 - 1.15 sec - Calculating Technical display
System manufacturer
System Product Name
  • None - 64-bit
AA level = None
Holomark 2 R6 v2,61
Total Score: 150346
GPU scores: 136150
GPU_01 - 634.90 fps - Cube 4 tests
GPU_02 - 42.20 fps - UDT Shape
GPU_03 - 714.30 fps - Wireframe
GPU_04 - 400.00 fps - Shaded
GPU_05 - 68.00 fps - Rendered
GPU_06 - 55.20 fps - Block Rendered
GPU_07 - 381 units Nurbs @ 5 fps in Wireframe
GPU_08 - 123 units Nurbs @ 5 fps in Shaded
GPU_09 - 30 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 125.00 fps - RenderMesh Render
GPU_11 - 322.60 fps - RenderMesh RenderSpeed
GPU_12 - 500.00 fps - JoinedMesh Render
GPU_13 - 909.10 fps - JoinedMesh RenderSpeed
GPU_14 - 177 units mesh @ 15 fps in Shaded
GPU_15 - 432 units mesh @ 15 fps in Render
GPU_16 - 1507 units mesh @ 15 fps in RenderSpeed
GPU_17 - 178.60 fps - mesh in Rendered Studio
GPU_18 - 14.50 fps - Nurbs in Rendered Studio
GPU_19 - 28.80 fps - Block Illustration
GPU_20 - 49.70 fps - 2D single
GPU_21 - 0.40 fps - 2D massive (20x)
CPU scores: 14196
CPU_01 - 7.36 sec - Booleans and Contours
CPU_02 - 2.61 sec - Twist and Taper (UDT)
CPU_03 - 4.30 sec - Meshing Mini
CPU_04 - 0.10 sec - Extract Render Mesh
CPU_05 - 0.03 sec - Join Render Mesh
CPU_06 - 15.26 sec - Reduce Mesh
CPU_07 - 1.06 sec - Calculating Technical display
CPU_08 - 4.50 sec - Making Silhouettes
System manufacturer
System Product Name
  • None - 64-bit
Rhino 7 sr 0 64 bit
AA level = 8
Holomark 2 R6 v2,61
Total Score: 153306
GPU scores: 139600
GPU_01 - 347.80 fps - Cube 4 tests
GPU_02 - 42.60 fps - UDT Shape
GPU_04 - 416.70 fps - Shaded
GPU_05 - 70.90 fps - Rendered
GPU_06 - 56.20 fps - Block Rendered
GPU_07 - 416 units Nurbs @ 5 fps in Wireframe
GPU_09 - 32 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 120.50 fps - RenderMesh Render
GPU_11 - 303.00 fps - RenderMesh RenderSpeed
GPU_12 - 454.50 fps - JoinedMesh Render
GPU_14 - 368 units mesh @ 15 fps in Shaded
GPU_15 - 419 units mesh @ 15 fps in Render
GPU_16 - 1501 units mesh @ 15 fps in RenderSpeed
GPU_17 - 142.90 fps - mesh in Rendered Studio
GPU_18 - 14.90 fps - Nurbs in Rendered Studio
GPU_19 - 29.10 fps - Block Illustration
GPU_20 - 51.30 fps - 2D single
CPU scores: 13706
CPU_01 - 7.30 sec - Booleans and Contours
CPU_02 - 2.69 sec - Twist and Taper (UDT)
CPU_03 - 5.64 sec - Meshing Mini
CPU_06 - 15.17 sec - Reduce Mesh
CPU_07 - 1.02 sec - Calculating Technical display
CPU_08 - 4.52 sec - Making Silhouettes
System manufacturer
System Product Name
  • None - 64-bit
Rhino 7 sr 0 64 bit
AA level = None
