Correct size of Revit Text Style
I try to get the Text-Size of a specific Text-Style, but somehow RiR displays the size with a factor of approx. 0.0001.
Is this related to the Revit file or do I miss some setting somewhere? I tried several ways, all leading to the same (false) results.
Maybe it has to do with the German version of REVIT? (My client uses the german version; I can’t switch to another language.)
Thanks in advance!
Those look like Revit Internal Units (decimal feet), you’ll need to do a conversion
In your case…
Hi @3achs1,
Thanks for reporting, this is fixed now on v1.16 and will be available on next v1.15 RC.
Hi Japhy,
so for the moment it is safe to choose a scale factor.
Thank You!
