Thank you!
Please answer this question as a solution could be much MUCH simpler than what you are doing.
Oh, sorry, i missed this question. I have a number of shapes, but I mainly work with this shape and another arch shape. I work with shapes that are mirrored quarters, because I want symmetry on all four sides
Also do you know how to get the gap between the flaps? In the former code i just used extend before offset, but with the connect curves node, the flap top seems to bend rather than uniformly extrude
Then there is NO REASON to deal with this in 3D! These are both developable surfaces. They map directly from the plane!
Unfortunately, I am running out of time. Please take your two basic forms (the extruded arch and truncated cone) and create a new thread asking “How do I map these surfaces to and from the plane?”. I can get back to you on the issue of the gap.
haha, yeah, maybe your right, but I started it this way and got locked to it. Thanks for all of your help, really appreciate it.
Here is a quick fix, but there is a better way to deal with this that gives you the gap based on absolute size:
Corner Sides Matching VR 7.gh (50.3 KB)
Please give me that other base surface.
Thank you, this works well. The other shape is attached
base shape.gh (21.5 KB)
Thank you. I just wanted to check. Yes, this too is a developable surface.
Yes, this is what I mean when I said:
Currently the gap is given as a percentage of the length of the cell side. You need to reformulate so that the gap is given by an absolute measure.
There is no point in persuing this further though. Creating developable surfaces that you can lay out in the plane should be your goal.
Here:
wallet original VR 1.gh (51.8 KB)
Basic base surface construction and the planar equivalent. Do your modifications to the mesh in the plane, create surfaces and sporph to target surfaces.
Adding what we had previously done to the current surfaces:
wallet original VR 2.gh (61.6 KB)
I know. It’s messy. Do you need the tabs on the sides? I think you will be able to surmise now why the reformulation of the surfaces was necessary if you think about those lines you wanted.
Thank you so much, I will try to transition to making flat patterns for the designs. The tabs tabs that you created will work really well I think.
Some clean up:
wallet original VR 3.gh (42.3 KB)
When I ask about the tabs I mean these here:
along the edge. Are these necessary? If no, just on one side, or both?
Oh ok, no, the tabs on the sides should be trimmed off and a clean edge should be on the bounding edges. I usually trim these off manually but if this can be done within Grasshopper, that would be cool
Is the target surface complete? Normally, it overlaps so that its profile is like a paperclip minus one turn. What is the thickness of you leather? Do you have a magnetic snap, or what kind of fastener will you be using to close the wallet? Or maybe this is a zipper type of wallet? I am assuming a women’s wallet here.
Yeah, the design is that it for it to look continuous but when the magnetic button is detached it you have just a rectangular piece of leather underneath it, and the sides are constructed with leather that you fold. So the looks like a whole piece from the outside, but its two pieces like a traditional women’s wallet. I usually use 2mm leather
I see, so it’s the front flap and backing piece. No variation in the covering length of the front flap? Or options of front flap contours to choose from?
I have to ask: why the complicated interlocking tab technique. That’s tedius handi-work. Why not just cut out the cells, glue them to substrate, and stitch over the cell edges. Are you going for a punk-rock look?
2mm seems thick. That’s handbag thick, not wallet thick. Something like 1.2 - 1.5 mm seems more reasonable. With a 0.5 - 0.8 mm appliqué, that comes to 2 mm anyhow.
Yes, a bit of an optical illusion, but saves time. Green shows what’s behind the fold.
Its tedious, but if the shapes are large, than its not too much work. Gluing it might be less tedious but requires more skillset and eye coordination than a connection mechanism, it is more tedious, but almost anyone with enough patience can do it.
2mm leather is sort of the thinnest leather I can source with the right attributes and thickness for the visual effect. It is not a wallet you put in your pocket.
One aspect missing in the code though is the mirroring. All of the designs are mirrored in the middle.
That I can still resolve. Let’s get back those lines you wanted though… What’s with them?
No, it’s the kind you put in your purse. I still assumed for that kind of wallet 2 mm would be rather thick. But I am not a leatherworker.
