Is it me does anyone else have a problem with the copy to clipboard function in grasshopper? I just tried copying text panel.
Hi djnelson75
did you write that code on top of the image yourself? If so, what was originally written?
If not, where did you type that text in the first place?
After this, I think @DavidRutten will be the one able to pinpoint the source of the issue.
Thanks
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
No I didn’t write it. This is the error message I get when I try to copy the text panel with the number “12” in that you see on the screen.
Are you running on a virtual machine?
Nope. Also this is version 0.9.0076.
No that’s the official error message when the clipboard just keeps throwing exceptions. I have never been able to pinpoint why sometimes the clipboard doesn’t work for someone, but when it doesn’t ten times in a row it’s pretty much a systemic problem rather than a bad luck streak.
