Copy/Paste text for naming a Relay does not work
Sequence
  • Create a relay component (by default, name is empty)
  • Copy a text (from another component name for instance)
  • Select the relay
  • Paste the text in the name
  • validate input by hitting “return” or RMB (Right Mouse Button)
Unexpected result
  • the Relay name stays empty
Workaround
  • before validation, add a space after the name and remove it,
system info.txt (2.5 KB)
I see that too. Logged in:
RH-53467 Grasshopper: Relay component: Pasted title does not stick
Thank you.
This should be fixed in the latest Rhino 6 for Mac SR17 Release Candidate.
