I’m trying to write a script that will enable me to copy the contents from a source directory to a destination directory using a Boolean trigger.
This is what I have. Something I scraped of the internet.
I get an Error (CS1501): No overload for method ‘RunScript’ takes 2 arguments (line 95)
private void RunScript(string sourcePath, string destinationPath, bool copy, ref object A)
if (copy)
if (!System.IO.Directory.Exists(sourcePath))
Print("Source directory does not exist.");
return;
if (!System.IO.Directory.Exists(destinationPath))
Directory.CreateDirectory(destinationPath);
foreach (string file in Directory.GetFiles(sourcePath))
string fileName = Path.GetFileName(file);
string destFile = Path.Combine(destinationPath, fileName);
File.Copy(file, destFile, true);
foreach (string dir in Directory.GetDirectories(sourcePath))
string dirName = Path.GetFileName(dir);
string destDir = Path.Combine(destinationPath, dirName);
RunScript(dir, destDir);
