Is there a way to copy and paste multiple materials between Rhino files. You can with one material but not if you select multiples. I know you can copy/paste geometry that brings the materials with it but with large interior files this really grinds my machine and also brings all the layer names etc.
Yes, I have the same question. How to load multiple materials at once instead of individually (one by one)?
Go to material editor, menu, import material from file, use shift key to select multiple material files
Hello - I’d use the copy/paste geometry trick by applying the materials to something simple like a line.
