Im new to Grasshopper/Rhino 8, so please be light on me.
I wanted to create a simple structure with openings using the Voronoi tool.
Everything has worked so far but I couldn´t figure out how to add the created Geometry (Facade with Voronoi openings) onto the Surface of the extruded Geometry (using the Surface Morph tool).
Its been showing the Error Notification “Data conversation failed from Extrusion to Surface”.
You can cast the extrusion to a brep then use the Deconstruct Brep component to get the individual faces (untrimmed surfaces) for use with the surface morph tool.
It still fails to morph the voronoi structure onto the Geometry I chose.
It somehow only morphs the structure onto one side of the body instead of covering the whole surface.
Not sure if it’s still relevant, but I was just doing the same tutorial (I think).
What I’ve done to work around this is move the original rectangle up and loft the bottom and the top one, instead of just extruding the curve as they do in the tutorial. This then creates a surface, which you can use for the morph.
