…as the title says. @dale Methinks this should work without having to force a conversion to a surface.
Edit : Python rhinoscriptsyntax equivalent seems to work OK with extrusions.
–Mitch
–Mitch
@dale Rhino.ExtendCurve is also failing with an extrusion object as a target - try the following scriptlet with the attached file - extend the red curve to the extrusion. It fails. Uncomment the line with the conversion of the extrusion to a surface and it will succeed.
@stevebaer The rhinoscriptsyntax method in Python is also failing in this case with an extrusion.
Option Explicit
Call TestExtendCrvToExtrusion()
Sub TestExtendCrvToExtrusion()
Dim crv,srf, result
crv = Rhino.GetObject("Select curve to extend", 4, True)
srf = Rhino.GetObject("Select extrusion to extend to", 1073741824)
'srf = Rhino.ConvertExtrusion(srf, True)'
result = Rhino.ExtendCurve(crv, 0, 0, Array(srf))
If IsNull(result) Then Call Rhino.Print("Extension failed!")
End Sub
Thanks, --Mitch
ExtendCrvToExtrusion-Fail.3dm (266.0 KB)
Got 'em, thanks!
– Dale
