private void RunScript(GeometryBase geometry, ref object Result)
if (null != geometry)
Result = geometry.GetType().ToString();
if(Result== "Rhino.Geometry.Brep")
Brep x = geometry;}
How does convert geometry Base
To Brep Or Mesh …?
603419608
(NARUTO)
August 12, 2021, 11:12am
2
rgr
August 12, 2021, 11:37am
3
var brep = geometry as Brep;
i test this method but One thing is not correct.
{ Result = geometry.GetType().ToString();
if(Result == "Rhino.Geometry.Brep")
{ var x = geometry as Brep;
A = x;}
else if(Result == "Rhino.Geometry.Mesh")
{ var x = geometry as Mesh;
A = x;}
else if(Result == "Rhino.Geometry.SubD")
{ var x = geometry as SubD;
A = x;}}
else
{A = "input Geometry must be Brep or Mesh or SubD";}
private void RunScript(GeometryBase geometry, ref object Result, ref object Geometry, ref object Re)
Geometry = x.MergeCoplanarFaces(RhinoDocument.ModelAbsoluteTolerance);
Re = Geometry;
Geometry = x;
Geometry = x.MergeAllCoplanarFaces(RhinoDocument.ModelAbsoluteTolerance, RhinoDocument.ModelAngleToleranceRadians);
Re = Geometry;
Geometry = x;}
subd = x.MergeAllCoplanarFaces(RhinoDocument.ModelAbsoluteTolerance, RhinoDocument.ModelAngleToleranceRadians);
Re = Geometry;
Geometry = x;}
else
{Geometry = "input Geometry must be Brep or Mesh or SubD";}}
@Mahdiyar
MergeAllCoplanarFaces+++.gh (30.6 KB)
rgr
August 12, 2021, 2:50pm
5
You should click on the error-bubble and read the acutal error-messages.
convert result to an object of type “string”.
in line 75 suddendly a object “subd” appears without being initialized.
read up on what parameters the mergeallcoplanarfaces() method takes for the mesh Mesh Class and subd SubD Class
thanks i success To slove that error![aa|690x235]
and this component is MergeAllCoplanarFaces for Brep Mesh and SubD
private void RunScript(GeometryBase geometry, bool MeshToSubd, ref object Geometry, ref object Result)
{ string R = geometry.GetType().ToString();
if(R == "Rhino.Geometry.Brep")
{ var x = Brep.TryConvertBrep(geometry);
Result = Geometry;
Geometry = x;
else if(R == "Rhino.Geometry.Mesh" && MeshToSubd == false)
Result = Geometry;
Geometry = x;}
else if(R == "Rhino.Geometry.Mesh" && MeshToSubd)
var y = SubD.CreateFromMesh(x);
Geometry = y.MergeAllCoplanarFaces(RhinoDocument.ModelAbsoluteTolerance, RhinoDocument.ModelAngleToleranceRadians);
Result = Geometry;
Geometry = y;}
else if((R == "Rhino.Geometry.SubD"))
Result = Geometry;
Geometry = x;}
else
{Geometry = geometry;}}
MergeAllCoplanarFaces+A.gh (27.5 KB)
