Turn list consisting of Breps and Extrusion into list with only Breps
I feel like there should be an easier way to do this which is the reason for this topic.
I’m working on a command which will do some stuff to an object which can be a surface, polysurface or extrusion. I’ve set the geometryfilter to “ObjectType.Brep” which seems to make sure I can select all of these types.
var go = new GetObject();
go.GeometryFilter = ObjectType.Brep;
while (true)
            var res = go.GetMultiple(1,0);
            if (go.CommandResult() != Result.Success)
                     return Result.Failure;
            break;
var objs = go.Objects();
Now afterwards I want to get a list of Breps so I can apply the same methods to these objects. But I can only know of a cumbersome way of doing it where I try to convert the geometry into the brep and if it doesn’t work try to convert the geometry to a extrusion to then convert to a brep.
var brlist = new List<Brep>();
foreach (var i in objs)
                var brep = i.Object().Geometry as Brep;
                if (brep == null)
                    var extr = i.Object().Geometry as Extrusion;
                    brep = extr.ToBrep();
                brlist.Add(brep);
Is there an easier/quicker way of doing this? Where I quickly get a list of Breps (since that is the geometry filter I am applying for selecting objects)
in RC you have tryconvertbrep
Brep.TryConvertBrep method (rhino3d.com)
This should work for you
Farouk
Thanks! @farouk.serragedine
