I have noticed that control points in 2D do not work yet. Unless a default lock has been put on?
p.s. where does one post items for update like this… Could there be a feed back button put in Rhino 6 under help?
Filters may apply
Jonathan Sheridan
www.e-DNA.co.uk
brian
(Brian Gillespie)
October 19, 2016, 6:22pm
2
Hi Jonathan,
Can you tell me more about what isn’t working for you? I can’t really tell what you mean from what you’re describing.
If you can reproduce the problem, can you please attach a model and describe the steps you take to repeat the problem?
Here! Please create a new topic when you have a new problem or question.
2d editing of control points doesn’t work… only moves whole dim… seems strange. could be something simple??
J
Jonathan Sheridan, MA (Ind. Des.) MPhil -
Electronic DNA Ltd. - www.e-DNA.co.uk http://www.e-dna.co.uk/
3D Design Visualisation & Geometry Automation
This e-mail and any files transmitted with it are private and confidential and are solely for the use of the addressee. It may contain material which is legally privileged. If you are not the addressee or the person responsible for delivering to the addressee, be advised that you have received this e-mail in error and that any use of it is strictly prohibited. Copying is prohibited. Electronic-DNA Ltd 2016
1658-LB-DETAILS 013-smal-test.3dm (2.23 MB)
brian
(Brian Gillespie)
October 25, 2016, 10:28pm
4
Thanks, I can reproduce that now. It seems to only happen when there’s another object and the Choose One Object menu would normally display.
This is logged as https://mcneel.myjetbrains.com/youtrack/issue/RH-36040
brian
(Brian Gillespie)
November 1, 2016, 11:07pm
5
This is fixed in Rhino WIP 6.0.16306.09301, just released.
