Is there a way to take control over layer visibility from custom UI elements residing in a separate DOM element? Looked into the ui.min.js
file but couldn’t find the corresponding function to call. Basically, I would like to recreate the functionality of this menu.
There is a small API that you can use. This is what the ui.min.js uses to turn things on and off.
For turning layers on and off you can use the following: http://mcneel.github.io/Iris/api#Iris.LayerOn
Thanks Luis! Exactly what I was looking for!
