Continuous 3D pattern across adjacent surfaces / Brep
Hello guys,
I am trying to map a continuous 3D pattern across a polysurface (Brep) consisting of multiple adjacent UV surfaces (NURBS). I’ve followed several tutorials and experimented with standard UV-mapping techniques, but my current skill level and workflow have reached a limit with this specific geometry.
Current Setup & Problem:
  • Geometry: A multi-face Brep / joined surfaces.
  • Issue: Applying the pattern per individual surface leads to misaligned tiles and topology distortion across the shared edge.
Thx a lot
TRIANGULATED_PATTERN.gh (12.5 KB)
SURFACES_FOR_JOIN.3dm (169.8 KB)
I didn’t do anything in grasshopper.
the other 2 parts of geometry (not referenced in your grasshopper file) have a decent topology, so I just merged the two surface and rebuilt it to equalize the UV spacing.
So I think, you should work on preparing the underlying surface topology of the other parts so you get a clean single surface for applying your pattern. It will also give cleaner edge conditions
There are many threads on surface (re)modelling approaches here in the forum. You will need to get rid of the patch and for that, generate a set of curves on the original geometry and build a new surface from tthere.
SURFACES_FOR_JOIN_dk.3dm (2.2 MB)
Thank you so much, @dk2079
Would it also be possible to perform surface joining (or surface stitching/stitching surfaces) on this closed object (AFO orthosis)? The model in the attached file was created using SubD modeling and subsequently converted into NURBS.
I am currently working on optimizing the trimlines (specifically the instep slot) to increase its flexibility. My initial approach using a variable offset (transitioning from thinner to thicker wall thickness) proved to be overly complex. I am now exploring whether patterning/perforating the surface (surface partitioning) would provide better elastic compliance for the slot.
Thanks
subd’s revenge :sweat_smile:
I would probably remodel a new base surface like this, and create a new offset from there:
luckily the shape is pretty compatible with nurbs surface layout.
Just around the heel it will require some attention to get the surface stretch right.
yellow are open curves, green are closed.
red are the surface edges, blue is a trim.
I would use _networkSrf
You could also build a new surface that is only exact at the edges(blue,red), and more loose in between and apply the pattern to this “low res proxy” and the pull the curves to your subd-nurbs object. The low res proxy will make it easier to adjust the pattern stretch
hope this makes sense!
