Continue Line from Spiral
Hello everyone, im wondering if anyone here can help me with this issue. Firstly, I want to continue my ramp from this spiral with a straight ramp to land, for instance, 10m far from the tower. Secondly, I want to add a dragon head to the ending point of the spiral ramp. I have attached both of my gh file and the image which I want to mimic.
Please excuse me if i can’t explain my issue/desire well since I have just learnt grasshopper a few day ago. I’m really thankful for anyone helping me on this matter.
Tower Lesson 01.gh (65.9 KB)
One way to lengthen the curve could be this.
But I think it is more convenient to use Pipe instead of Offset.
Ramp.
This fragment shows two ways of extending a curve that preserves tangents at both ends:
  • Extend Curve
  • BiArc
I internalized ‘Crv2’ but it can be baked and moved around to make the connection smooth.
Tower Lesson_2025Sep28a.gh (9.7 KB)
Im sorry that i didn’t attach those plugins.
I don’t want any plugins :bangbang:
Thank you sir. This means alot to me. May I know how can I structure the dragon head attached to the spiral tube shape.
Thank you sir. This could be it. I’m learning from your solution now. If you don’t mind, i would like to ask if u could you me how to structure those dragon head attached to the tube spiral.
You have a lot to learn, grasshopper.
Thank you sir for your time and solutions. It means a lot to me.
Thank you again sir
You can connect the dragon head using Loft.
If it helps you, there are sites where you can download 3D dragons. (https://free3d.com/3d-models/dragon)
Obviously you will only have to use your head.
See an example here.
Wow this is the solution im looking for. Could you show me the gh file of how you connect this head to the spiral tube via loft.
This is my interpretation but it can be improved.
Tower Lesson 01 a.gh (3.1 MB)
Thank you sir. It means alot to me. I still haven’t figured out how to cloose the spiral tail so that it will look like a round dragon tail at the end
thank you so much sir
