Hello everyone ( Grasshoppersmiths ) ,
I have created a Grasshopper definition that is intended to bake geometry into a specific layer using the Context Bake component, with Grasshopper Player. I’ve tested the script, and everything functions as expected, except for one issue: the baked geometry doesn’t go into the intended layer or sublayer.
Here’s what I’ve done so far:
- I used the Bake Layers component from the Elefront plugin to create the layers.
- The GH script runs without errors, and the geometry bakes correctly, but it ends up in the default layer instead of the specified one called “Vertical Line.”
Has anyone encountered a similar issue or have any insights on how to ensure the baked geometry is nested in the correct layer when running through Grasshopper Player?
I’m attaching an image and the .gh file for reference. Any help would be greatly appreciated!
Thank you advance …@,>>-
Bake.gh (18.7 KB)
