I always forget how to do this!
I have 4 rectangles and I want to create quad mesh faces from them.
I can do one strip at a time but how do I create all the strips?
ConstructMesh.gh (8.0 KB)
Loft?
ConstructMesh_loft.gh (12.1 KB)
I want those specific quads so I can convert it to a SubD afterwards.
I think that you can code. If Iām correct get the attached and modify it accordingly (most notably the Polyline Array).
Mesh-alongCurve_EntryLevel_V1.gh (18.1 KB)
Iām not sure if thereās a native component that does this, but hereās a simple Python function for meshing point grids, that I implement on pretty much every project I work on:
Er⦠not really. I once used to be able to use VB and have cobbled together some stuff in GH script editor but I am self taught! Thanks for the example though, I like the extra control this gives and am sure it will come in handy for situations where this is needed.
This is great, thanks. You should make it a component, itās really useful and this is slightly beyond what is capable with native components (I think)
One question⦠Why is U count 5?
Itās to close the resulting grid around back where it starts (i.e. each rectangle is represented by five vertices, where the first and last overlap). Also, we should probably add mesh.Vertices.CombineIdentical(True,True) after making the grid, as the current code will leave a naked edge loop at the seam.
It converts to a SubD OK, but I will try and add that line of code as it sounds like good practice
Like this? I get an error saying āname āmeshā is not definedāā¦
Ah sorry, I meant within the function. If you call it on that line use Mesh (upper case M). And donāt reassign it to a variable. The method edits the mesh in place. On my phone ![]()
Here are some thoughts on doing it with vanilla Gh (you could also identify the points and have an even cleaner Construct mesh, by specifying them as the corners in MeshQuad, but Iāve run out of lunchtime, sorry)
ConstructMesh.gh (24.6 KB)
Credit:
I picked up this workflow on the old Gh Forum "4 points surface" to Mesh - Grasshopper
Brilliant, thanks!
Challenge completed!
I always forget about the Relative Item component.
The data manipulation from the End Points through the Merge components is hard to visualise but I can follow it.
Iām out of time, but in case youāre interested in a ready-to-use compiled component, froGH already has a Polylines Mesh Loft component:
So, half of that script was actually redundant it turns out - the Merge I guess has two key moments:
Then, letās draw out what weāre trying to do so we can visualise it better - see how the direction has to be reversed for the top polyline segment - and we can formally define if we start with item i - we need to access the following elements:
Once weāve drawn it out, we can get really wacky with our relative items - see below how to address it if the points are in a tree structure or if theyāre in a flat list - this wonāt be as fast as scripting or a compiled component, but it helps us visualise the logic at least:
ConstructMesh.gh (36.1 KB)
Thank you! I need to study this when Iām back next week but this is really helpful, educational stuff, thank you again!
Someone is upsizing his board handleā¦
