I am designing a stiffened shell structure with Karamba.
However, the stiffeners are not fully clamped and degrees of freedom have to be released with respect to the shell. I guess the best way to model this is to use springs with zero length. I was inspired by the tutorials on this subject.
Unfortunately, I’m not able to merge/duplicate the right points and get the right spring connectivity (3 points at the same place). In my example, the springs are placed between the beam parts when the beams should be continuous and be released from the shell (Definition is attached)
Thanks in advance for your help!
Nicolas
ZeroLengthSpring.gh (31.3 KB)
