column.gh (14.5 KB)
I am practicing avoiding relative item, so when I try to make diagonal lines, some extra slanted vertical lines form which I cant get rid of , anybody know what is happening?
column.gh (14.5 KB)
you can use the Relative Item component and specific {path offset} [item offset]
yes, but im trying to not use relative item because of sorting problem
can anyone tell , even if I can make diagonal lines with relative, how do I sort them ?
In the file @inno posted above, the lines are grouped in branches by X-positions and then sorted by Y-positions.
What is your desired result?
-Kevin
thanks, that will do
Added options to sort by X, Y or Y, X and ascending or descending:
column_re_kr-02.gh (12.8 KB)
-Kevin
