Connecting curves with surfaces to get a volume - best way?
Hi
Thank you for taking your time to read this post. I have two simple curves with I need to connect to get a volume - final it should lead to a 2mm tin in an u-shape - see attached file.
Pobably it is very simple, but I didn’t find a proper way to get a volume.
Thank you for any hint. Jens
Nischen_20240223.3dm (805.7 KB)
You can use the _Loft command and then _Cap to close the planar open ends.
Nischen_20240223.3dm (94.2 KB)
Thank a lot Martin. It is very helpful.
