What is the command to join two closed curves?
For example, I’ve drawn an oval on the “ground plane” and a circle a few feet above it. Both are open (unfilled) and I’d like to 1) make them solid, or, filled, and 2) loft between them (or whatever the command may be called).
I realize there are likely a few ways of doing this, but I am new to the software and haven’t found the commands.
Thanks!
