Connect Crv and Close Crv
I have a bunch of open curves and try to use Connect Crvs to make them closed.
However I found that maybe its because their directions are not sync so that the result went wrong (as the image shown).
I thought about Flip Curve but in a bunch like this I don’t know what should be the guide.
Any help would be appreciated!
Close crv.gh (48.5 KB)
the problem is the gaps:
you could close them increasing the tolerance in Rhino, or in GH, like this:
 private void RunScript(List<Curve> crvs, double tol, ref object A)
    A = Curve.JoinCurves(crvs, tol);
(The Code is also in the file)
However one crvstays open:
you may just want to delete it
File:
Close crv_Re.gh (50.1 KB)
Thanks man it does make the curve closed.
However I realize some of them are self-intersect and its because the original surfaces have problem need to clean up. So here’s my other thread.
