Hello everyone,
I’m running Rhino.Compute on an AWS virtual machine. When I open Rhino on the VM itself, it clearly shows that the document units are set to meters. However, whenever I make a request through Rhino.Compute, the JSON response indicates the geometry is in millimeters. This mismatch is causing confusion and also increases calculation time due to the unintended scaling factor.
I’m wondering if there is a Compute-side or headless Rhino setting that could be forcing units to millimeters. Any suggestions on how to ensure the output units match the model units I’ve set (i.e., meters) would be hugely appreciated!
Thanks in advance!
We have the same problem. How can we make the output of a script is in meters instead of millimetres.
@Erik_Beeren ```
sc.doc.ModelUnitSystem = Rhino.UnitSystem.Meters
https://developer.rhino3d.com/api/rhinocommon/rhino.rhinodoc/modelunitsystem
Alternatively, for RhinoCompute, you can setup a template in Meters.
Farouk
So for Rhino Compute you’re saying just select the Metres template and check the box for starting Rhino each time with that template?
Wanted to give some information because this issue popped up again for us last week sometime and we finally solved it (for our usecase at least)
We were relying on the helper function EvaluateDefinition, which defaults to millimeters. Our solve was to rewrite that function and directly hit the /grasshopper endpoint, allowing us to supply things like modelunits and tolerances.
