Does anyone know if it’s possible to analyze composite action beam/slab structures in Karamba? In other words - to analyze the behavious and effect of the addition of beam/rib elements onto a surface
thanks!
thanks!
Hi, you can simulate ribs of a slab by dividing the beam into segments and using the division points as points on your shell (You can use the MeshBreps component for this). Then when you input the segmented beam and integrated shell into the same model, Karamba3D will know that they are connected.
