I am quite new on Karamba. I was trying to model a sandwich beam.
I have created a top and bottom beam element, and to simulate the core, I have made a shell element with the same thickness of the base of my beam.
My model seems to work fine, I don’t get any error. But the result in the displacement differs by 16% with my analytical calculations. I have also tried to make a model with another FEM software, and the result confirms that the analytical calculations are fine, while the Karamba model is not.
What is wrong in the Karamba model? I guess I am missing something… 04.Sandwich Beam Model.gh (51.4 KB)
I have a similar problem. I’m trying to simulate a sandwich beam using Karamba. The sandwich structure consists of 3 layers, each layer should have a different height and material. Currently, I use a shell for each layer since the layers are, compared to the dimensions of the beam, relatively thin.
Unfortunately, I have no idea how to join the stacked layers / shells together. So far, only the core layer (on which the force is applied) shows a displacement.
If anybody has a hint for how to solve my problem, please let me know.
In the end, I would like the core layer to be a shell with a varying height, while the top and bottom layers have consistent heights but follow the shape of the core layer. Does anyone have a hint/idea for how to realize this once the other problem is solved?
you could try to tie together the nodes along vertical lines using short pieces of beams which have a dummy material of zero weight and act like dowels.
You would have to experiment around with the dowel shear stiffness which is controlled bxy the shear areas Ay and Az and the material stiffness.
–Clemens
Is there another possibility of joining these layers together? Or would that necessitate volumetric FEA (on the roadmap?)? I am currently looking into a similar challenge (especially with the varying height).
Hey, it seems to be on the roadmap of Karamba - but unclear, when or if it will be available. I also found Alpaca4D, which supports sandwich cross sections.
I did need the sandwich cross section to do some quick analysis for some basic ideas regarding my thesis, but switched the strategy anyway, so I can’t yet really speak from much experience regarding sandwich elements.
